JD 6120 No Glow Plug Light, No start
   / JD 6120 No Glow Plug Light, No start #1
CassieMack
John Deere 6120
I have a 2004 JD 6120, went to start it and have no glow plug light and of course it will not start. I didn't force the start without the light on. I am finding nothing in the manual, nothing on YouTube on this tractor at all.
   / JD 6120 No Glow Plug Light, No start #2
When you say no start does that mean it turns over but will not run? Or the starter is not spinning the engine?
It should run without the glow plugs energized unless it is really cold where you live.
It turns over just fine but will not start at all since the glow plug is not working. I read somewhere to turn it over for 5 seconds then let it set for 5 seconds and do that a few times and it would start without the glow plug. So I tried that, and nothing.
   / JD 6120 No Glow Plug Light, No start #4
I suspect it is not getting fuel to the injectors. Could be the fuel stop solenoid is not getting power. Because the glow plugs are not working and it doesn’t run, it could be a ground issue for the relays or blown fuses.
   / JD 6120 No Glow Plug Light, No start #5
I don't see "glow plug" shown in 6120 parts catalog but I see an air intake heater & a fuel heater. Cold start aid should only be required in sub-freezing temperatures. I see cold start advance kit which changes inj pump timing during cold temperatures. Have you checked for a blown fuse? Is inj pump fuel control solenoid receiving 12 volts when ign switch is turned to on position??
   / JD 6120 No Glow Plug Light, No start #6
I
Right. The glow plug ligt not working is probably a symptom of something else not working electrically.
A diesel with normal compression in summer weather will normally will start just fine without the glow plugs being actuated at all.
I'd loosen a fuel line at one of the injectors, crank it for a few seconds, and see if you get fuel squirting out there. If not, go looking for why. It will make a bit of a mess, but is a quick diagnosis.
UNUSED MOWERKING SKID STEER AUGER SET (A50460)
UNUSED MOWERKING...
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A48081)
2008 Ford F-250...
2019 CATERPILLAR TH255C TELESCOPIC FORKLIFT (A50458)
2019 CATERPILLAR...
2007 International 7600 Tandem Truck, VIN # 1HSWYAHR37J478209 (A48836)
2007 International...
UNUSED KJ 33' X 25' DBL GARAGE STEEL BARN SHED (A50460)
UNUSED KJ 33' X...
Fork Extensions (A48837)
Fork Extensions...
