JD-59 snowblower hydraulic cylinder
   / JD-59 snowblower hydraulic cylinder #1
Wkorzen
John d
The hydraulic cylinder for the chute rotator on my JD59 snowblower is leaking. I'm choking on the $351 that John Deere wants for a new one. I'm sure there's a similar ( and cheaper) cylinder available with a little research. Has anyone replaced this cylinder with a similar item? I' be interested to know the make and model you selected. I don't mind making minor modifications to the mounting brackets.
The stock hydraulic cylinder is JD part number AM126765.
Thanks.
   / JD-59 snowblower hydraulic cylinder #2
Why not just give us the open and closed length, bore size, rod size, stroke size, and end mount description.
You are not locked in to JD are you?
2002 MACK CH613 (A53843)
2002 MACK CH613...
2012 DOOSAN G25 GENERATOR (A53843)
2012 DOOSAN G25...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2018 CATERPILLAR 299D2 XHP SKID STEER (A52705)
2018 CATERPILLAR...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
SKID STEER BRUSH ATTACHMENT (A53843)
SKID STEER BRUSH...
