JD 5603 inoperable pto
/ JD 5603 inoperable pto #1
JimB77
Bronze Member
'11 Kubota M7040, '91 JD 4255, '81 Ford 6700, '45 JD BO
My knowledge of these JD/Yanmar tractors is very limited. I'm attempting to help my nephew diagnose this tractors pto problem. I've been researching the 5603 parts catalog & I've determined pto is driven by a dry clutch that's manually operated by cable on clutch housing. I can't determine how flywheel transfer power to trans input shaft. I determined foot clutch pedal only controls an electronic switch. Is anyone familiar with how the 540E changes speeds? Could this 540E control rod be in neutral position?
Thanks for any assistance, Jim
Inspected the tractor. PTO E speed change lever mechanism wasn't engaged properly. Pto shaft spins when engaged & engine operating BUT stops turning when pressure is applied to shaft with a 2X4. PTO clutch is probably slipping.
I agree & that's exactly what I told my nephew.
PORTA POTTY (A67714)
2009 POLAR TANK . (A67714)
2009 POLAR TANK ...
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
Generator Inverter (A64553)
Generator Inverter...
2024 CATERPILLAR 265 SKID STEER (A65056)
2024 CATERPILLAR...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
