JD 5575 specs
/ JD 5575 specs #1
zuiko
Platinum Member
Minnesota
JD 990 4WD
Anyone have specs for a JD 5575? Weight, max lift, hp, etc? I haven't been able to find anything.
/ JD 5575 specs #2
Let's see... 5575.
Horsepower, net: 37. (39 gross)
Displacement: 100.1 cubic ingches
Engine rpm: 3000
ROC: 1410 lbs
Breakout: 3405 (bucket)
Axle torque: 3914 ft-lbs.
Speed: 6.7 mph
Hydraulic pressure: 2650 psi
Hydraulic pump: 10.0 GPM
Bucket capacity heaper: 11.5 cu. ft.
Length with bucket: 120 inches
Width less bucket: 58.8 inches
Height to ROPS: 72.8 inches
Dump reach: 24 inches
Bucket rollback: 36
Dump angle: 45 degrees
Wheelbase: 37.4 inches
Grand clearance: 8.1 inches
/ JD 5575 specs #3
Forgot a few specs...
height to hinge pin: 111.1 inches
Axle torque (corrected -- incorrect in previous post): 2969 ft-lbs
Operating weight: 4500 lbs.
Keep in mind the 5575 is equivilent except for engine to the New Holland Lx485. (No longer produced; now is the Ls150.)
/ JD 5575 specs
Thanks for the info!
/ JD 5575 specs #6
The JD 5575 was manufactured by New Holland and is essentially a New Holland LX 485 with a Yanmar engine.
2018 Dodge 5500 Bucket Truck 4WD (A63689)
2018 Dodge 5500...
2015 FREIGHTLINER M2 24FT REFRIGERATED CDL REQUIRED BOX TRUCK (A59914)
2015 FREIGHTLINER...
1996 Sunflower 1543-38 Folding Disk (A63688)
1996 Sunflower...
2008 New Holland T2420 (A62177)
2008 New Holland...
2011 JOHN DEERE 672G MOTORGRADER (A63276)
2011 JOHN DEERE...
2006 CATERPILLAR 307C EXCAVATOR (A63276)
2006 CATERPILLAR...
