JD 5575 specs
   / JD 5575 specs #1
zuiko
Platinum Member
Minnesota
JD 990 4WD
Anyone have specs for a JD 5575? Weight, max lift, hp, etc? I haven't been able to find anything.
   / JD 5575 specs #2
Let's see... 5575.
Horsepower, net: 37. (39 gross)
Displacement: 100.1 cubic ingches
Engine rpm: 3000
ROC: 1410 lbs
Breakout: 3405 (bucket)
Axle torque: 3914 ft-lbs.
Speed: 6.7 mph
Hydraulic pressure: 2650 psi
Hydraulic pump: 10.0 GPM
Bucket capacity heaper: 11.5 cu. ft.
Length with bucket: 120 inches
Width less bucket: 58.8 inches
Height to ROPS: 72.8 inches
Dump reach: 24 inches
Bucket rollback: 36
Dump angle: 45 degrees
Wheelbase: 37.4 inches
Grand clearance: 8.1 inches
   / JD 5575 specs #3
Forgot a few specs...
height to hinge pin: 111.1 inches
Axle torque (corrected -- incorrect in previous post): 2969 ft-lbs
Operating weight: 4500 lbs.
Keep in mind the 5575 is equivilent except for engine to the New Holland Lx485. (No longer produced; now is the Ls150.)
   / JD 5575 specs
Thanks for the info!
   / JD 5575 specs #6
The JD 5575 was manufactured by New Holland and is essentially a New Holland LX 485 with a Yanmar engine.
BUYER'S PREMIUM INFO LOT NUMBER 2 (A53084)
BUYER'S PREMIUM...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51246)
2021 HAMM HD+9I VO...
2011 Kia Sportage SUV (A51694)
2011 Kia Sportage...
2016 Ford F-350 Ambulance (A51692)
2016 Ford F-350...
2019 Caterpillar 966M Articulated Wheel Loader (A51691)
2019 Caterpillar...
40' High Cube Multi-Door Container (A50123)
40' High Cube...
