jd 5525 wheel hub oil
   / jd 5525 wheel hub oil #1
Slippy
Veteran Member
Ohio
Mahindra 6000 4wd; IH x2; NHTC40DSS; International 1086; JD 5115M
I purchased a jd 5525 with 650 hrs and want to check/change the front wheel hub oil. the manual seems to say use HY-GARD oil, but that seems to be the same oil to use in the hydraulic system. Is this correct? I would think the front hubs take something more like a 90-120w gear oil.
   / jd 5525 wheel hub oil #2
Yes, that's what is called for in my JD 66415 too. Might be the low speeds it sees does not build up the heat a truck axle would
   / jd 5525 wheel hub oil #3
Hygard is the correct oil per the owners manual. Some models do use 80/90 or 85/140 gear oil. I have sometimes found the factory fill oil is not the same as manual recommendation. In my opinion, either one will work. I actually prefer the heavier gear oil in the hubs also. If you do alot of high speed driving on the road, I would stick with the Hygard.
2005 Mack CV713 Granite Truck, VIN # 1M2AG11C55M020965 (A51572)
2005 Mack CV713...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
JOHN DEERE LOT NUMBER 121 (A53084)
JOHN DEERE LOT...
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
TMA (A49461)
TMA (A49461)
