JD 5520 brake loss after hard use. Any ideas?
   / JD 5520 brake loss after hard use. Any ideas? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
My 5520 brake pedal goes to the floor after the tractor really gets used hard and is good and hot. After it cools down a bit, the brakes are back.
It happened twice. Once on a 20 mile road trip and last night after chisel plowing a few acres. I checked the owner's manual but it only tells you to step on the pedal to stop the tractor. No more. The brakes are hydraulic wet disc, whatever that means and I have no idea where to look or what to do.
Any ideas or could someone point me in a direction? Thanks.
   / JD 5520 brake loss after hard use. Any ideas? #2
I've never seen or heard of brakes on a JD act as you describe. Does brake pedal fade occur when both brake pedals are applied together? You could try bleeding the brakes which process is very similar to automobile. Bleeders are on top of axle housings.
   / JD 5520 brake loss after hard use. Any ideas? #3
Twenty mile road trip??? Tire replacement will soon be another discussion topic. All that aside you aren't using the brake pedal for a foot rest are you? That could cause the brakes to heat up. Also where is the brake master cylinder located? is it in a area that is exposed to heat being generated by the engine or driveline when in use? The fluid in the master cylinder could be being heated causing your problem. Find the brake fluid reservoir and check the temperature of the contents when the problems occurs.
   / JD 5520 brake loss after hard use. Any ideas? #4
wet disk means they are bathed in oil. This seems a strange problem because during 20 mile trip, you shouldn't be having to use the brakes that much.
Do they have bleeders if in oil? Brakes locked together and tractor was really hot both times. When cooler, no problem and brakes are back.
Haven't used the brakes hardly ever. Only discovered extent of issue when I was loading on trailer last night and almost didn't stop.
No on the foot on the pedal. I'm a textbook operator with few bad habits.
The road trip was to pick up a piece of equipment I bought at auction only to learn they did not have a loader tractor available. I have radials so they will wear out a very long time after I do. I have maybe 60 road miles on them and they look 100.00%.
   / JD 5520 brake loss after hard use. Any ideas? #7
Brake bleeder is parts key #4
   / JD 5520 brake loss after hard use. Any ideas? #9
Impressive that you found that. Thank you.
It was easy to locate as the bleeder is in the same location as JD 1020/2020 & later utility tractors plus I was employed by a JD dealer for over 21 years working in parts dept selling parts a portion of the 21 years. FYI radial tires do wear out from traveling on blacktop highways. I've driven my tractors many miles on blacktops since I've been in the custom hay baling business since '87. Different tire tread designs/brands wear better/worse than others. The best wearing tire I've ever owned is a Continental radial long bar/long bar.
I've got Firestones and love them. Great pulling power and they allow me to go over soft areas without much of a mark. I have seen those Continental ties and they do look pretty good--and expensive. While I am rarely on blacktop, guys around here have farmland scattered everywhere and seem to always be on the road. Radials do wear but around here they sure seem last a long time. In fact, it is rare to see a bias tire except on smaller equipment.
On the brake thing, there is also a hydraulic valve that has something to do with it. I called a large Deere dealer around here and he could not find a brake issue like this that had happened before. He was at a loss to explain.
If I were to bleed them would that mean you think air in the line might be an issue?
My plan is to go to a Deere dealer next week and take a look at a shop manual to try to narrow things down and if I can't figure it out let the dealer try. What do you think of that idea?
Woods BW12 Batwing Mower (A50514)
Woods BW12 Batwing...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2017 Ford F-150 Pickup Truck (A50323)
2017 Ford F-150...
KJ Double Ply Polyester Webbing Sling (A50121)
KJ Double Ply...
(10) 20' Continuous Fencing Panels (A50515)
(10) 20'...
Skid Steer Gravel Leveler (A50515)
Skid Steer Gravel...
