JD 5510 Problem
   / JD 5510 Problem #1
mitchash
Greene, NY
Mahindra MAX 28XL, Jinma 254 (Sold)
I was brush cutting in the back field when our 5510 just quit (it has just over 6000 hours). It turns over, there is over half a tank of fuel, I checked the fuel filter, bleed the system (fuel is comming out of the injector bleeder but not a lot), it did run for a few minutes then died again.
Anyone have any ideas?
Thanks,
Ash
   / JD 5510 Problem #2
Thanks,
Ash
Clogged fuel filter or air filter would be my first two guesses.
It doesn't sound like a safety switch since it ran for a few minutes.
I'd suggest you replace the fuel filter first and see if it starts. If it doesn't, replace the air filter. If it still doesn't start, it's possible it skipped timing.
Gas Pump Artwork (A55758)
Gas Pump Artwork...
2015 Ford F-250XL (A53314)
2015 Ford F-250XL...
2015 Ford Taurus SE Sedan (A55853)
2015 Ford Taurus...
Henderson Stainless Steel Salt Spreader (A50775)
Henderson...
2018 New Holland Workmaster 60 4x4 Tractor with Loader (A54865)
2018 New Holland...
2007 Ford Explorer SUV (A55758)
2007 Ford Explorer...
