JD 5510 Cab MFWD / 14' BWA
   / JD 5510 Cab MFWD / 14' BWA #1
tbashin
SE Texas
John Deere 5510, Massey Ferguson 230
So I picked up a bigger section of land and the little old MF 230 won't cut it so I picked up a JD 5510 Cab MFWD. This place has black land and sandy areas. It has decent grass in spots but needs working. The place hasn't been turned in 30 plus years so I want to renovate/disc it. I found a nice 14' BWA disc in great shape locally but wasn't sure about how the 5510 and BWA would act together. Thoughts?
   / JD 5510 Cab MFWD / 14' BWA #2
Thoughts? How about a location in your profile? tks, as that helps understand better.
Trying to understand "black land and sandy areas".
"BWA" disc .. ??
:welcome: to TBN
We like pics, and hope to keep up with your land development adventure.
In South central TX it is well known. Black clay but fertile is the best way I can describe it. Hard as heck when dry and gets big cracks. Once moisture gets right it is fairly easy to work but a little too wet and it痴 wet black clay consistency again.
   / JD 5510 Cab MFWD / 14' BWA #4
Welcome to TBN
I think a 75 pto HP MFWD tractor should pull a 14' JD BWA disk harrow in black soil just fine. Sandy soil might cause one to need to lower harrow carrier tires a little. Another thought if harrow is too much load for 5510 is to adjust disk angle less. I still remember selling/delivering new JD BWA disk harrows.
Thanks for your responses and advice, very helpful.
2014 Ford F-150 4x4 Crew Cab Pickup truck (A55973)
2014 Ford F-150...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2015 Ford Fusion Hybrid Sedan (A56859)
2015 Ford Fusion...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1ET4EKG11918 (A57453)
2014 Ford F-150...
2016 John Deere 5055E 55HP Utility Tractor (A55973)
2016 John Deere...
2020 Freightliner Derrick Digger Truck (A55973)
2020 Freightliner...
