JD 550C Track
/ JD 550C Track #1
JBandTTractor
What is the easiest way to get a track back on a bulldozer? I broke the track apart and put it back on, it stayed on for about 30 minutes. This time the track off the front roller and the back sprocket but still under the center. Can someone please give some advice, thanks.
/ JD 550C Track #2
I believe on the adjustable idler puller arm, you would loosen a nut. That will release the grease, and the arm will retract. After you remount the track, tighten the nut and regrease the fitting, and the arm will extend. Be sure to keep both sides at the same tension. The best way to get the track on would be to pull it with a excavator or backhoe, and a few long bars. I recall the nut and grease fitting were under a hinged panel, at least on my 450E. But I only lost a track once, and that was many years ago.
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
2021 VERMEER LP573XDT VACUUM TRAILER (A63276)
2021 VERMEER...
CROP CARE PLASTIC PLOW / LIFTER (A63291)
CROP CARE PLASTIC...
2003 CASE 70XT SKID STEER (A64279)
2003 CASE 70XT...
2018 TAKEUCHI TL8 SKID STEER (A64279)
2018 TAKEUCHI TL8...
