jd 544c loader hydraulic issues
/ jd 544c loader hydraulic issues #1
sodfarmer101
live oak fl.
jd 544c
My jd 544c loader was working fine one minute and then it lost all hydraulics. Just had steering cylinders remanufactured. Checked fluids and changed filters. Driveshaft from engine to transmission is not spinning as quickly as the engine. When I put it in gear it feels like it wants to move but something is slipping. Intermittently, the steering is strong, the loader and drive work, but only slowly. Its a tired machine but it was all working fine for two hours then just stopped. I know of two pumps on the loader. I thought the one on the tranny ran drive and steering and the one behind the engine (under radiator) was the one that ran the loader. Makes no sense why both go out and the engine still runs fine.
/ jd 544c loader hydraulic issues #2
My knowledge of JD ind equip is limited although I understand closed center hyd's. The 544C has closed center hyd system. It has to have a charge pump supply oil to the main frt pump under radiator. Slower drive shaft speed vs engine speed sounds as if damper plate(parts key 10) is failing which in turn would slow charge pumps output.
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A61307)
Neckover GL24-2-7K...
2015 Ford Escape SUV (A59231)
2015 Ford Escape...
2009 CHEVROLET C8500 DUMP TRUCK (A59823)
2009 CHEVROLET...
2019 John Deere R-4038 (A61306)
2019 John Deere...
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
HITACHI EX550LC EXCAVATOR (A58214)
HITACHI EX550LC...
