JD 5425 tach problem
   / JD 5425 tach problem #1
duckduke
Ethel
Ford 5900
Status is when I start tractor..... idle RPM=0. If i rev throttle the RPM starts going up but maxis out at 12-1500 RPM. Other wise runs well and everything is working fine.... Just RPM is not registering correctly.
I figured it had t b the tach/RPM sensor. Put a new sensor on ($40) ..... Same thing.... No change.
I spent 3-4 hours today cleaning wire connections and grounds. Same thing .... No change.
A little baffled. Any comments would b appreciated. Thanks!!
INGERSOLL RAND G25 GENERATOR (A58214)
INGERSOLL RAND G25...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
TANK MANIFOLD (A55745)
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
NEW HOLLAND HAY CUTTER (A58214)
NEW HOLLAND HAY...
