JD 5425 Lever I - Hydraulics
   / JD 5425 Lever I - Hydraulics #1
rustywinslow
jackson, tn
JD Gator 825i
We have a JD 5425 and one side of the rear Hydraulics has stopped working. Worked fine last time out yet was unusually hard to disconnect when thru. Next time out, nothing on the left side. Right side works fine, we don't ever use the mid-mount so no idea if it works or not. I assume it does as everything else on the tractor works fine. You can hear the RPM's reduce when the Lever I is pushed/pull yet nothing happens.
I know less than nothing about how all of this works. I'm looking for some self-checks or anything I can rule out prior to having to have it picked up and carried to the shop. Solenoid?
   / JD 5425 Lever I - Hydraulics #2
No solenoid involved.
Sounds like it might be the quick coupler. One or both. Try swapping them with the ones on the right side valve.
Mower King Brush Cutter (A53317)
Mower King Brush...
403 (A52706)
403 (A52706)
EXCAVATOR RIPPER (A58214)
EXCAVATOR RIPPER...
Sterling 9500 (A56436)
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
