JD 5420 Broken Front Axle Support
   / JD 5420 Broken Front Axle Support #1
patladner
Anchorage AK and Pass Christian, MS
JD 5420 with Cab & 1952 Cub
My 5420 2WD has about 950 hrs on it. Two weeks I was bushhoging and I ran into a sink hole in the field. There was a pretty good jolt but the tractor didn't stop. Yesterday, I was using the front end loader and noticed that the front wheels were moving backwards and forwards about 3-4 inches. After checking, I found that the large front axle support was broken. However, the break was very symmetrical about 4 inches on each side of the pivot and down were the power steering bolts onto each side. I could see if I was going 20 miles per hour and hit a solid concrete 2 ft high wall but this looks like a bad casting. Any similar experiences?
   / JD 5420 Broken Front Axle Support #2
How old is the tractor?
Maybe the dealer will do something for you.
It has been out of warranty for several years. It just doesn't have many hours on it. The dealer said that he would have the JD representative take a look at it to see if there wasn't a defect in the support piece.
   / JD 5420 Broken Front Axle Support #4
Sounds like that will be the best course.
   / JD 5420 Broken Front Axle Support #5
I've got a 5400 2WD ( not the Yanmar version) and that front trunion is huge and beafy. If your is similar it would had to have a defect. At least my front end looks large enough for 100HP tractor. Hard to imagine it breaking there from a ground hog hole. Of caurse stranger things have happened.
Everyone who has looked at it said that it looks like a bad casting. It would be understandable if it had broken on the right side of the pivot bushing because the right wheel ran into the hole. However, you could not draw a more perfect fault line in a perfect semi-circle around the pivot rod where this large piece of steel cracked.
I took it into the JD dealer on Monday and they have contacted the JD Rep. So we'll see what they think. I know there are JD tractors that are larger than mine but hauling that big boy on a trailer is really scary, especially when there is a little wind.
   / JD 5420 Broken Front Axle Support #8
I haul mine all the time with loaded tires, front loader with 800lb grapple on it, and an attachment on the rear too.About 9500lbs in all. Yep its aload all right.
2018 WACKER NEUSON RTSC3 ROLLER (A54607)
2018 WACKER NEUSON...
2022 Kubota L2501D Compact Tractor (RIDE AND DRIVE) (A50775)
2022 Kubota L2501D...
Mini Excavator Rake (A53316)
Mini Excavator...
Toro GreensMaster 1600 Walk-Behind Reel Mower (A53421)
Toro GreensMaster...
2021 JOHN DEERE 7R230 LOT NUMBER 204 (A53084)
2021 JOHN DEERE...
2015 FORD F150 XL SINGLE CAB TRUCK (A51406)
2015 FORD F150 XL...
