JD 542 with MX 10 Bushhog broken shaft
   / JD 542 with MX 10 Bushhog broken shaft #1
Palmetto boy
Rock Hill, SC
John Deere 542 / Loader / MX 10 Bushhog
Gentlemen, I have broken the input shaft to the gearbox after the chain sprocket (coupler). The shaft comes from center gearbox to the outer gear box that is connected to the blades. It is the smaller shaft that go into the gearbox. Can I weld it or should I replace the whole unit. The JD dealer mentioned that they changed the design to eliminate the breaking. Please help, any idea would be appreciated!
   / JD 542 with MX 10 Bushhog broken shaft #2
I think you will be wasting time and welding rod to weld the shaft. I'd recommend replacement of the shaft. Have you checked the slip-clutch to be sure it's not frozen?? I'm curious how does the model 542 FEL enter into the title of this thread?
   / JD 542 with MX 10 Bushhog broken shaft #3
Thanks for posting. There has been a lot of MX 6 gearbox failures, now an MX 10. If it looks like it can be welded, I would try that, much cheaper than a new gear box.
   / JD 542 with MX 10 Bushhog broken shaft #4
i also would just replace the shaft.also check slip clutch.
2024 Dig Master DM100 Mini Excavator, NEW! (A52384)
2024 Dig Master...
Duetz Power Unit (A50120)
Duetz Power Unit...
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2016 Arising 8.520VTRW 22ft T/A Enclosed Cargo Trailer (A51694)
2016 Arising...
