JD 5400 Starting Procedure
   / JD 5400 Starting Procedure #1
k2ds
Cambridge
JD 5400
My Father died a few months ago and I went home to bushhog the fields. I can not get the tractor to start. And yes it has fuel in the tank. It is a JD 5400 and I haven't driven a tractor in 30 years but I have drive alot of older tractors in my life, JD A , Farmalls, and others along with some heavy equipment.
I have never felt this dumb in my life. It will turn over but that is it. HELP!
   / JD 5400 Starting Procedure #2
It might not be turning over fast enough...try jumping the battery and cranking the engine.
   / JD 5400 Starting Procedure #3
Make sure all of the controls are in neutral. Move the hand throttle about 1/4 way up . Also make sure the pto is off. Should start as long as it has a good battery and is turning over fast enough.
Good luck
Sean
   / JD 5400 Starting Procedure #4
If it hasn't been started in a long time .. try priming the lines. There is a plunger on the fuel filter. Push it a few times. If the engines is turning over the safeties are satisfied or jumped out.
2005 Cummins DGBB 43.7 kVA 3-Phase Diesel Generator (A46683)
2005 Cummins DGBB...
2021 23ft Cypress Cay Seabreeze 232 Pontoon Boat with 23ft Single Axle Trailer (A48082)
2021 23ft Cypress...
Century 3pt Sprayer (A49251)
Century 3pt...
4 Test Lot (A49732)
4 Test Lot (A49732)
2018 New Holland H7330 Haybine (A49251)
2018 New Holland...
8 Titan Bush Hog, 3pt hitch, PTO  (A47371)
8 Titan Bush Hog...
