Snow JD 54" QH snowblower removal
   / JD 54" QH snowblower removal #1
dmay
Winnipeg, MB
2010 JD2320
JD 54" QH Snowblower
01 - 54" QH snowblower
02 - spout cable
03 - hydraulics
04 - snowblower drive shaft
Snowblower removal
05 - remove spout cable
06 - coil spout cable around chute
07 - disconnect chute rotation hydraulics and coil around chute
08 - leave QH hydraulics connected
09 - disconnect snowblower driveshaft and place on support rod
10 - unlock front hitch levers
11 - use a dolly for easy snowblower storage moving
Quick Hitch Removal
12 - lift QH and slide dolly under snowblower
13 - lower QH and back away. Use dolly to move snowblower.
14 - raise QH
15 - disconnect QH hydraulics and coil for storage, unlock levers, lift and remove QH
Front PTO driveshaft and front hitch removal
16 - disconnect front PTO driveshaft at mid pto. Pull back on colar to release. Move forward to clear mid pto.
17 - move driveshaft rearward to pull out of front pto bearings
Front PTO hitch removal
18 - to remove front pto hitch
19 - pull out retainer rod and lift out hitch assembly
Final Steps
20 - Almost done. Now service and grease all components removed so they are ready to go next time.
   / JD 54" QH snowblower removal #2
Dmay thanks for that post nice job. I couldn't resist copying all the photos for future reference.
smalltown
   / JD 54" QH snowblower removal #3
Dmay,
Excellent job... :thumbsup:
I wanted to ask you. How did the plastic impeller hold up this past winter? Anything major stand out or is it still rock solid.. I see by your pictures you have your blower set up pretty high off the ground. Is that for the stone in your driveway?
Thanks :D
Dmay,
Thanks :D
I have had no problems to report after my first year of heavy use. I have ~9000 sq ft of gravel that I clear so I keep the snowblower shoes one below the highest/lowest position (depending on your perspective). This helped to avoid sending gravel through the impeller and chute.
   / JD 54" QH snowblower removal #5
Have the impellers been plastic for a while now or is this something new?
After seeing what the occasional rock does to my old single stage thower it just seems odd to go to plastic.
   / JD 54" QH snowblower removal #6
I believe the impellers have been plastic since JD came out with the 54" snowblower. The 47" still has the steel impeller. From what i've read if you damage the plastic one all you have to do is order a steel one from a 47" snowblower.
   / JD 54" QH snowblower removal #7
RaisedonDeere wouldn't the impeller on the 54" be longer to make it a 54" ?
   / JD 54" QH snowblower removal #8
02 - spout cable
03 - hydraulics
Snowblower removal
Quick Hitch Removal
14 - raise QH
Final Steps
Good info give to john deere to help improve there instructions on how to put it on :2cents:
   / JD 54" QH snowblower removal #9
That is the auger...the impeller or fan that they are speaking is in the rear and what "blows" the snow out of the chute.
   / JD 54" QH snowblower removal #10
Smalltown,
As Kennyd stated the item you are talking about is the spiral auger. That is almost 54" inches in length. That auger funnels and pulls the snow into the item we are talking about which is the impeller which thrusts the snow out the chute.
Woods 3 PT Blade (A52349)
Woods 3 PT Blade...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
Payment Terms (MUST READ) (A50775)
Payment Terms...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2022 New Holland Powerstar 90 Tractor with Loader (A51573)
2022 New Holland...
