JD 54" bucket cubic yard capacity
/ JD 54" bucket cubic yard capacity #1
deere_x475guy
Eaton Rapids, MI
JD 4110
JD 54\" bucket cubic yard capacity
Hi everyone, I thought that I remember seeing some place that the cubic yard capacity was 1/3 of a yard. Do any of you know if this is true?
/ JD 54" bucket cubic yard capacity #3
Re: JD 54\" bucket cubic yard capacity
Found this on the web at Stonehams. This is from a 200CX loader. Are other loader buckets similar? BTW, 1 yd = 27 cu. ft.
Hope this gets you close.
BUCKET SPECIFICATIONS
Bucket Type
Width
Struck Capacity
Weight
Materials Bucket
1250 mm (49-in.)
0.17 cu. m (6.0 cu. ft.)
70.2 kg (155 lb.)
Materials Bucket
1350 mm (53-in.)
0.22 cu. m (7.8 cu. ft.)
82.9kg (183 lb.)
Materials Bucket
1550 mm (61-in.)
0.25 cu. m (9.0 cu. ft.)
86.1 kg (190 lb.)
/ JD 54" bucket cubic yard capacity #4
Bucket Type
Width
Struck Capacity
Weight
Materials Bucket
1250 mm (49-in.)
70.2 kg (155 lb.)
Materials Bucket
1350 mm (53-in.)
82.9kg (183 lb.)
Materials Bucket
1550 mm (61-in.)
86.1 kg (190 lb.)
/ JD 54" bucket cubic yard capacity #5
Has anybody ever monitored or measured the differences between level filled buckets, which I assume the above numbers are, and heaped buckets? 1/3 of a cubic yard sounds about right for 53" with a little heaping.
We need someone to perform a science experiment of moving a known pile size from one location to another keeping track of number loads it takes with a healthy amount of "heaping" - good ballast is assumed. Surely, with all the new owners looking for seat time, this shouldn't be a problem. I would but I can't seem to get the dirt man and weather aligned yet...
/ JD 54" bucket cubic yard capacity #6
Thanks bglombowski yes it does. I seem to recall thinking that 3 buckets would get me close to a yard.
I have to move fill from the back of my property to the front of my home to take some of the steep grade down. Going to be a lot seat/loader time. I will probably post something in the projects folder with pics.
Thanks again
Thanks again
New/Unused Quick Attach Soil Conditioner (A61166)
New/Unused Quick...
New/Unused Fuel Heater (A61166)
New/Unused Fuel...
New/Unused AGT SDA-140W Wheel Loader (A61166)
New/Unused AGT...
DURA-CAST PRO-LICK TANK (A62131)
DURA-CAST PRO-LICK...
3ft. Wooden Native American Statue (A61569)
3ft. Wooden Native...
UNUSED CFG INDUSTRIAL H15R MINI EXCAVATOR (A62130)
UNUSED CFG...
