Oct 3, 2009 / JD 5310 #1 Gizmo36 Platinum Member Joined Nov 26, 2005 Messages 708 Location East of Duewest S.C. any know were the fuel bleed screws are on a JD 5310 . the fuel pump don't look like any I have seen
Oct 3, 2009 / JD 5310 #2 J jd110 Veteran Member Joined Dec 31, 2001 Messages 1,587 Location Maryland The only bleed screw is the one on the fuel filter housing. Bleed it at the filter, then loosen the line at the injection pump that comes from the filter. If you get all the air out of that, it should start.
Oct 4, 2009 / JD 5310 #3 S sixdogs Super Star Member Joined Dec 8, 2007 Messages 13,726 Location Ohio Tractor Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C That's the way it is on my 5520.
Oct 4, 2009 / JD 5310 Thread Starter #4 OP Gizmo36 Platinum Member Joined Nov 26, 2005 Messages 708 Location East of Duewest S.C. I got all the air out at the filter and to the top of the pump. then my battery was dead I will have to go back today and see if it will start.
