JD 5303 lift arms will not lower
   / JD 5303 lift arms will not lower #1
emrs
My lift arms on my JD5303 will not lower. I have them loaded with a steel table (300 -400 lbs) on my boom pole. lifted the table all the way up but it will not lower it down. All other hydraulics seem to be fine, transmission and power steering.here has been no indication of lift problems up to this point.
   / JD 5303 lift arms will not lower #2
Welcome, Do you have a valve down buy your feet that controls the amount of drop of the 3 point?
   / JD 5303 lift arms will not lower #3
There should be a descent control knob under the seat.
Turn in to lock for transport, or turn counterclockwisr to slowly descend or turn more counterclockwise for fast descend.
   / JD 5303 lift arms will not lower #4
The following post my solve your problem. Also you may want to do a search on this site on 5303 to help solve your problem.
The problem maybe in the rate of drop valve under the seat. Make sure you get the 3PT and attachment on the ground or brace it up! It will come down when that valve is removed.
http://www.tractorbynet.com/forums/attachments/259103-jd-5403-3-pt-wont.html
Thanks for information on bracing up. I have tried to turn the knob counterclockwise- No action. I will try to remove the rateof drop valve as soon as i get a chance and will report back what I find out. Thanks
UNUSED RAYTREE RMT48-48" TRENCHER (A51248)
UNUSED RAYTREE...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
2012 Audi Q5 AWD SUV (A51694)
2012 Audi Q5 AWD...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A53472)
2015 Ford F550...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
