JD 5303 lift arms will not lower
   / JD 5303 lift arms will not lower #1
emrs
My lift arms on my JD5303 will not lower. I have them loaded with a steel table (300 -400 lbs) on my boom pole. lifted the table all the way up but it will not lower it down. All other hydraulics seem to be fine, transmission and power steering.here has been no indication of lift problems up to this point.
   / JD 5303 lift arms will not lower #2
Welcome, Do you have a valve down buy your feet that controls the amount of drop of the 3 point?
   / JD 5303 lift arms will not lower #3
There should be a descent control knob under the seat.
Turn in to lock for transport, or turn counterclockwisr to slowly descend or turn more counterclockwise for fast descend.
   / JD 5303 lift arms will not lower #4
The following post my solve your problem. Also you may want to do a search on this site on 5303 to help solve your problem.
The problem maybe in the rate of drop valve under the seat. Make sure you get the 3PT and attachment on the ground or brace it up! It will come down when that valve is removed.
http://www.tractorbynet.com/forums/attachments/259103-jd-5403-3-pt-wont.html
Thanks for information on bracing up. I have tried to turn the knob counterclockwise- No action. I will try to remove the rateof drop valve as soon as i get a chance and will report back what I find out. Thanks
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
2000 GMC C7500 Flatbed Truck, VIN # 1GDM7H1C4YJ505285 (A51572)
2000 GMC C7500...
2015 F-550 Bucket Truck. (A53472)
2015 F-550 Bucket...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A53472)
2018 John Deere...
2021 Fendt 1050 Vario Tractor (A53342)
2021 Fendt 1050...
