JD 5301 3 point hitch stuck
   / JD 5301 3 point hitch stuck #1
deputyave
Searcy, Ar.
John Deere 5103
I've got a JD 5301 and the 3 point hitch is stuck in the up position. It only has about 60hrs on it. Any ideas?
   / JD 5301 3 point hitch stuck #2
Is your rate of descent knob fully closed?
Turn left to open.
   / JD 5301 3 point hitch stuck #3
I agree with J_J to check R-O-D screw but JD 5000 series have a history of the rockshaft control sticking not allowing 3 pt to lower. Is your tractor still covered under warranty?
I will check that today it is currently at a friend's place. It is not under warranty bought it at an auction.
   / JD 5301 3 point hitch stuck #5
The title is 5301 did you mean to say 5103?
Before doing the following make sure if you something attached to the 3 pt you brace it up or take it off if you can.
Here is a post to look at, also go to JD parts catalog for a picture of the rate of drop looks
http://www.tractorbynet.com/forums/hydraulics/107218-jd-5103-3-point-hitch.html?highlight=5103
John Deere - Parts Catalog
In thread #4 a member says
I just fixed my tractor that also had only 60 hours on it. The problem is corrosion in the rate of drop valve located underneath the seat. Remove the seat, and you will find the valve that controls the rate of drop. Be prepared for some hyd fluid to leak out and the hitch to drop. Remove the three allen head screws and remove the cover. Inside the cover you will find a cylinder about 3/4" in diameter. Pull it out using a pliers, it may be stuck. This is the first place you will notice the corrosion. Once you have the cylinder out, there is a plunger on the opposite end. This plunger/piston is what is jammed or stuck. Break it loose and work it till it operates freely. There isn't much else you can do to it other than clean it. Then reassemble. According to the dealer I spoke with, the problem is caused by the fluid absorbing moisture, thus causing the corrosion. No recommendation for prevention, but it is an easy fix once you have done it.
Yes it's a 5103 I guess I'm a bit dyslexic I'm going to try this as soon as possible thanks.
   / JD 5301 3 point hitch stuck #7
Hi,
I have a Jimna 284 and my 3 point linkage is sticking up. I pulled out the hydraulic cyclinder and the seal/wiper ring was broken. Bought a new seal kit but no instructions does anyone know which seals to replace as the kit has numerous in it?
   / JD 5301 3 point hitch stuck #8
On my 254ts near the 3 pt arms and attached to revamp near the 540/1000 (?) lever control there is another lever that locks the 3pt in the up position .. Without a manual I don't have names for these things but u may have the same situation considering it's Chinese ...
   / JD 5301 3 point hitch stuck #9
Thanks,
I have replaced the O rings but now the piston will not slide back into the cylinder any ideas, keeps sticking/jamming on entry.
2019 GEHL RT105 SKID STEER (A51246)
2019 GEHL RT105...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
Case Maxxum 140 (A50120)
Case Maxxum 140...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A52748)
UNVERFERTH 330 8...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
