jd 5300 Transmission troubleshoot repair questions
   / jd 5300 Transmission troubleshoot repair questions #1
Holiday_the_cat
I am a grad student at UCSD and as a side fun project, I picked up a 5300 that needed a little tlc. Engine now runs perfect, pto and rear hydraulics for three point hitch work fine.
Unit has a power reverser transmission - unit does not engage to move forward or reverse. Picked up the tech manual in cd format from JD and started looking at the diagnostic ports. High pressure port is wet, forward and reverse ports look dry (and yes it would be nice to have the pressure gauges to properly do the diagnostic but I am a student!). Suspected the interlock so pulled the reverser and found nothing - also no metal residue in the bottom of the tranny.
Is there an interlock I am overlooking? Any Ideas? Thanks Bob
I plan to post the complete sequence of tear down with pics later! Is here a current area on the web for videos of tractor repairs?
   / jd 5300 Transmission troubleshoot repair questions #2
Can't quite answer your power reverser question but a hydraulic gauge is only about $15-$20 from Northern tools.
2016 KENWORTH T270 S/A SERVICE TRUCK (A51406)
2016 KENWORTH T270...
2014 Ford F-150 Pickup Truck (A55788)
2014 Ford F-150...
Case 1083 20ft Corn Head (A55301)
Case 1083 20ft...
UNUSED LANDHONOR LDH-FPR36 - 36" FIRE PIT RING (A54757)
UNUSED LANDHONOR...
2016 Ford Explorer AWD SUV (A55758)
2016 Ford Explorer...
2015 Ford Taurus SE Sedan (A55853)
2015 Ford Taurus...
