jd 5300 Transmission troubleshoot repair questions
   / jd 5300 Transmission troubleshoot repair questions #1
Holiday_the_cat
I am a grad student at UCSD and as a side fun project, I picked up a 5300 that needed a little tlc. Engine now runs perfect, pto and rear hydraulics for three point hitch work fine.
Unit has a power reverser transmission - unit does not engage to move forward or reverse. Picked up the tech manual in cd format from JD and started looking at the diagnostic ports. High pressure port is wet, forward and reverse ports look dry (and yes it would be nice to have the pressure gauges to properly do the diagnostic but I am a student!). Suspected the interlock so pulled the reverser and found nothing - also no metal residue in the bottom of the tranny.
Is there an interlock I am overlooking? Any Ideas? Thanks Bob
I plan to post the complete sequence of tear down with pics later! Is here a current area on the web for videos of tractor repairs?
   / jd 5300 Transmission troubleshoot repair questions #2
Can't quite answer your power reverser question but a hydraulic gauge is only about $15-$20 from Northern tools.
2016 FREIGHTLINER M2 DAY CAB (A51222)
2016 FREIGHTLINER...
2025 GIYI Skid Steer Plate Grabber (A50322)
2025 GIYI Skid...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
S Houle WD-10B Pull-Behind Hydraulic Turf Aerator Tractor Attachment (A49461)
S Houle WD-10B...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2013 Chevrolet Malibu Sedan (A50324)
2013 Chevrolet...
