JD 5300 Transmission Shifter
   / JD 5300 Transmission Shifter #1
JoeBob394
Hoschton,Ga
John Deere 5100R
1996 JD 5300 with collar shift transmission.
The gear shift has lost its normal side to side travel limits and instead has to be pulled far to the left (against the set bottom nearly) to engage the left two gears (reverse over and back etc.) It is like the lever has lost its travel restriction entirely. You can hunt around and engage the gears so it seems it may be in the linkage.
Any thoughts would be appreciated.
   / JD 5300 Transmission Shifter #2
Hey neighbor. I have copies of the Deere technical manual and parts manuals you're more than welcome to.
Shoot me your email if you want them.
And howdy from Cumming, GA!
Joe
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
2003 Ford F-650 Flatbed Truck, VIN # 3FDNW65243MB03484 (A48836)
2003 Ford F-650...
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
2020 KUBOTA SSV75 WHEELED SKID STEER (A51242)
2020 KUBOTA SSV75...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
2015 FREIGHTLINER  CASCADIA (INOPERABLE) (A50854)
2015 FREIGHTLINER...
