JD 5210 milky hydraulic fluid
   / JD 5210 milky hydraulic fluid #1
bjhaffly
Poolville, Texas
JD 5210
I have drained all fluid, changed filter, cleaned strainer. Put in new hydraulic fluid twice. within 2 weeks fluid is tan colored/milky. First time it was foamy and tan. Seems like water may be entering the picture but I can't figure out how or where. Anyone had this issue?
   / JD 5210 milky hydraulic fluid #2
I would recommend keeping a tarp on it if left outside.
   / JD 5210 milky hydraulic fluid #3
Have a look at the tractor and see if you can't spot where the water is coming in. Gear shift or pto levers. Is it running down the levers and following the linkage to the transmission case. Are the boots around the levers in good shape?
Thanks for the responses. After reading these threads I inspected the boots on the shifter and indeed both are cracked and worn. A tarp sounds like a good quick fix for now but I will invest in new covers also.
Thank you
   / JD 5210 milky hydraulic fluid #5
I THINK that there is a version of "seafoam" made for getting water out of trans/hydro fluid. Once you get your boots fixed it may help- it can be tough to drain all the water out!
   / JD 5210 milky hydraulic fluid #6
Thank you
Also, invert a bucket over the shift levers, at least till you change the boots.
Rgds, D.
   / JD 5210 milky hydraulic fluid #7
Also be sure the breather on the hyd reservoir is open IE not plugged so condensation can evaporate when hyd oil reaches operating temp..
Hey guys I really appreciate all the tips and advice.
Thanks,
BJ
p.s. Where is Coyote Flats?
   / JD 5210 milky hydraulic fluid #9
It's in a triangle between Cleburne,Grandview & Alvarado. It was voted in 2010. The people that drew the city limit boundaries were smoking "wacky backy" or consuming something illegal.
JOHN DEERE 1705/6700 (A53084)
JOHN DEERE...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A55302)
2017 Yale GLC050VX...
Michigan L90 (A47477)
2015 Ford Escape SUV (A55758)
2015 Ford Escape...
Nissan CF60 6,000lb LP Forklift (A55851)
Nissan CF60...
