JD 5210 Hydraulics Hot
   / JD 5210 Hydraulics Hot #1
jgbanshee
PA
JD 310SE, 4300, 5300, 5210, 450 Crawler, CAT D3B, Ford 2N, 5000, 4000su, 3610, 345C, 340B, 1100
I was flail mowing a few acres (2 hrs) of field yesterday with my 5210 sync reverse trans. and was temp outside was about 80 degrees. When I was done mowing I took a short road trip back home. I noticed I had no brakes. The pedal would just push in with no brake whatsoever. Was not like this earlier and today after everything has cooled down. I assume this is due to excessive heat on the hydraulic fluid. Hydraulics work yesterday/today. What should I be looking into, hyd. pump and relief valve??
   / JD 5210 Hydraulics Hot #2
If everything else was working as it should then I would say it's may not be heated fluid but something actually wrong with your brakes. You call it a sync reverser which I've never heard of. I had a 5310 with a sync shuttle and they offered a power reverser. You need to do a bit more troubleshooting and determine if other hyderaulic functions are working when this happens.
   / JD 5210 Hydraulics Hot #3
1st thing I'd suggest checking is how clean is hyd oil cooler. Is scv control valve centered in neutral?
Sorry, it is sync shuttle trans. My 4300 has the sync reverser. 3pth seems to work fine, loader and p/s definitely have a noticeable difference in performance almost sluggish and jerky when hot. Hyd. fluid level looks good when cool but seems to drop when hot. All hyd. levers do return to center/neutral position.
   / JD 5210 Hydraulics Hot #5
Time to dig out the workshop manual and determine if the braking system uses the same hydraulic fluid as the rest of the hydraulically driven items and then adjust your investigation as appropriate. I would expect, but don't truly know, the braking system's hydraulic fluid would be separate from general use hydraulic fluid since brakes are a life safety critical item.
   / JD 5210 Hydraulics Hot #6
5210 uses hyd oil for brake fluid. Hyd pump keeps brake valve reservoir replenished with hyd oil
   / JD 5210 Hydraulics Hot #7
5210 uses hyd oil for brake fluid. Trans pump keeps brake valve reservoir replenished with hyd oil
OK, so the trans pump keeps the brake fluid reservoir filled with the general use hydraulic oil but when you step on the brake, I expect, that pressure is transmitted directly to a braking disk and thus the two systems are essentially separate vs actuating the brake tells some other valve to correspondingly open and transmit hydraulic pump pressure to the brakes. A mechanical system vs brake by wire.
   / JD 5210 Hydraulics Hot #8
No hyd pump pressure is applied to brakes. Pressure is created by piston in brake housing being pushed by brake pedal sending oil into brake line to wheel piston.
Correct, but it does use the same oil as the hyd. system.
   / JD 5210 Hydraulics Hot #10
Based upon your responses, jgbanshee should be focusing his attention on the braking system as it is separate from the general hydraulic system except the trans pump keeps the brake fluid reservoir filled.
If no brakes means no reduction in speed or very little reduction when brakes applied then I would be looking at routing of brake lines near heat sources and whether he boiled the hydraulic fluid in brake circuit OR his hydraulic fluid has some water contamination in general hydraulic circuit or specifically in brake circuit and the heat boiled the water. Liquids are substantially in-compressible at temperatures tractors experience but vapor ( boiled water or hydraulic fluid boiled ) is very compressible.
Boiling would explain why brake returned after tractor cooled down.
Brake fade and loss come from 40 years of racing cars.
John Deere 8430 Track Tractor (A50514)
John Deere 8430...
2016 Mercedes-Benz GL450 4MATIC AWD SUV (A50324)
2016 Mercedes-Benz...
2005 Kobelco 135SR Hydraulic Excavator (A50322)
2005 Kobelco 135SR...
1996 CUSTOM ALUMINUM 16FT CAR TRAILER (A52141)
1996 CUSTOM...
ATTENTION PLEASE READ (A50121)
ATTENTION PLEASE...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
