jgbanshee
- Joined
- Sep 16, 2004
- Messages
- 316
- Location
- PA
- Tractor
- JD 310SE, 4300, 5300, 5210, 450 Crawler, CAT D3B, Ford 2N, 5000, 4000su, 3610, 345C, 340B, 1100
I was flail mowing a few acres (2 hrs) of field yesterday with my 5210 sync reverse trans. and was temp outside was about 80 degrees. When I was done mowing I took a short road trip back home. I noticed I had no brakes. The pedal would just push in with no brake whatsoever. Was not like this earlier and today after everything has cooled down. I assume this is due to excessive heat on the hydraulic fluid. Hydraulics work yesterday/today. What should I be looking into, hyd. pump and relief valve??
