JD 5210 How To Remove Tie Rod?
   / JD 5210 How To Remove Tie Rod? #1
JD5210
Virginia
5210 MFWD
I am trying to separate the tie rod from the knuckle on the MFWD swivel housing of my 5210, so that I can replace the boot. I have the nut loose. I tired hitting hard with a big hammer the knuckle to break things loose, with no luck. I have jacking up the tie rod a little and then hit the knuckle with the hammer, no luck. I tired using two hammers holding one on one side and hitting with the other on the other side. I do not have fork big enough. I have tired jack up the axle if maybe the tire was binding anything up. The repair manual did not provide any suggestions. I currently have them sprayed with penetrating oil.
Any suggestion on how to remove the tie rod would be appreciated. Thanks in advance for any help.
   / JD 5210 How To Remove Tie Rod? #2
You may have to resort to one of these tools.
Thanks, looks like I will need to get a pickle fork.
   / JD 5210 How To Remove Tie Rod? #4
Hammers have always worked for me, might have to hit it real hard helps to have pressure on tie rod in the direction it needs to go to come off
   / JD 5210 How To Remove Tie Rod? #5
A hammer has always work for me also. Like magic with a little down pressure on the tie rod and smack the casting in the direction indicated in the picture.
That would be the strongest (for not cracking the casting) direction to hit it.
View attachment JD 650 LF axel spindle.pdf
   / JD 5210 How To Remove Tie Rod? #6
Then again, you do risk shattering the casting... so calculate the risk and consider the options. ;)
Thanks for the suggestions. I ordered a pickle fork on Sunday, should be here in the next few days.
(4) CAMARO 5 LUG WHEELS & 245/50R16 97H TIRES (A54757)
(4) CAMARO 5 LUG...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
2118 (A58376)
2118 (A58376)
BRIGGS & STRATTON 127CC GAS MOTOR (A52708)
BRIGGS & STRATTON...
23018 (A55758)
23018 (A55758)
2000 Ford F-650 Truck, VIN # 3FDNF6541YMA65799 (A57453)
2000 Ford F-650...
