JD 5205 Has Blinking Hour Meter Display
   / JD 5205 Has Blinking Hour Meter Display #1
Zebulon101
John Deere 5205
I have a John Deere 5205 where everything in the small hour meter display (which also has miscellaneous symbols in it) is blinking all 8's. I haven't noticed any operational differences in the way it runs or operates (other than the fact that I have no idea how many hours I have on the tractor).
Anyone have ideas on how to correct this problem?
Thanks!
   / JD 5205 Has Blinking Hour Meter Display #2
The electronics in the "gauge" are probably shorted out from water etc.
My guess would be, you need a new gauge.
   / JD 5205 Has Blinking Hour Meter Display #3
Thanks!
Hi,
I have a 5205 that just started blinking. Did you figure out issue?
   / JD 5205 Has Blinking Hour Meter Display #4
Thanks!
Did u findout the issue
   / JD 5205 Has Blinking Hour Meter Display #5
I also have a 5205 with about 1775 hours on it that just started blinking hour meter display with same symptoms. Kept in a shed so I don't believe its a moisture problem. A new display is $478. Hoping someone knows of a fix.
   / JD 5205 Has Blinking Hour Meter Display #6
Thanks!
I see this is an old post. Did you find a solution for this?
PORTABLE INDUCTION HEATER (A52472)
PORTABLE INDUCTION...
Electric Forklift Pallet (A50322)
Electric Forklift...
KJ U-Type Shackles (A50121)
KJ U-Type Shackles...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
2001 Ford F250 Pickup (RUNS) (TITLE) (A50774)
2001 Ford F250...
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
