JD 5105 no start
   / JD 5105 no start #1
cloahsark
Hey there . So I have this 5105 . Seat was siezed and wouldn't slide so listed it off tractor to grease it, unplugged two safety wires under seat and there is a largish wire on one of rear bolts holding seat down , I assume it's a ground. Anyway greased seat put it back and plugged in two safety wires ales large wire on bolt to tractor rear end at back of seat, simple. But now the dang thing will not turn over, lights work but it's as though range lever was not in neutral or some other safety device. No clue where to start looking any help appreciated.
Bruce
   / JD 5105 no start #2
The seat switch does not affect starting, but if not working the PTO alarm will go off when you use the PTO.
The only safety switches are the PTO and tractor in neutral.
I have attached a starting system for the 5105. Start by check that the PTO is off.
  • 5105starting_system.pdf
   / JD 5105 no start #3
Start where you began. Verify all switch connectors to the seat are tightly fit together and the 'ground' bolt has a solid connection where paint is not interfering with the ground function. Try to start again.
   / JD 5105 no start
Thx for the Info that's gonna help, pretty sure it's pto related.
   / JD 5105 no start
Neutral safety switch was undone, mess of muck covered it and my eyes suck. Thx for the diagram.
   / JD 5105 no start #6
Glad you got fixed and thanks for letting us know what you found. You may want to purchase the tech manual at selectmanuals.com
2006 Kenworth T600 Semi (A50514)
2006 Kenworth T600...
2018 Infiniti QX30 Premium SUV (A50324)
2018 Infiniti QX30...
New Holland 155 Hay Elevator (A50774)
New Holland 155...
UNUSED FUTURE MINI EXCAVATOR HYD WOOD DRILL (A51244)
UNUSED FUTURE MINI...
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
2018 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51242)
2018 CATERPILLAR...
