JD 5103 fuel guage
   / JD 5103 fuel guage #1
rrpratt
Willingboro, NJ
John Deere 2305
The fuel guage stays at empty. I do measure resistance across the connectors of the sensing unit. Also have about 4 volts DC to it. Guage never moves. Sound familiar to anyone?
   / JD 5103 fuel guage #2
If you take both wires off the sensor and put them together. With the tractor NOT started and the key in the run position does the fuel gauge go to full? If the gauge does not go to full, then problem is in the cluster or the wiring to the cluster.
Will check that in the morning. Thanks
   / JD 5103 fuel guage #4
check your private
messages
   / JD 5103 fuel guage #5
I have the same problem with the fuel guage on my 5225. It used to read empty when about 3/4 full. Starting yesterday, the tank is full and the guage still reads empty. I'll try JD5210's suggestion.
2023 CIMC 53X102 REEFER TRAILER (A52576)
2023 CIMC 53X102...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
Generac 5000Watt Heavy Duty Diesel Generator (A51691)
Generac 5000Watt...
2021 FORD TRANSIT 250 CARGO VAN (A52576)
2021 FORD TRANSIT...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
