JD 5103 3 pt hitch help
   / JD 5103 3 pt hitch help #1
country2
In the spring I used a spring tooth chizel plow, when I disconnected I raised my lift arms. Well now they will not go down, The rate knob is set right and my rocker shaft lever is set right. Any one have any thoughts.
   / JD 5103 3 pt hitch help #2
Do you have any weight on them? Might not go down without some weight on the arms. It's gravity that lowers most 3 pt hitches.
Thanks for the reply. I have stood on them and moved the levers and rate knob. I have read about people taking a hammer in the valve area, I may try that but I am afraid I am going to have to pull the cap off the housing.
2020 CATERPILLAR 938M WHEEL LOADER (A51242)
2020 CATERPILLAR...
Massey Ferguson 65 Loader Tractor (A50514)
Massey Ferguson 65...
2005 MACK GRANITE GU713 DAY CAB (A51219)
2005 MACK GRANITE...
HUSKY 135 PSI AIR COMPRESSOR (A50854)
HUSKY 135 PSI AIR...
E-Z Trail Head Cart (A50514)
E-Z Trail Head...
2018 Chevrolet Tahoe SUV (A50324)
2018 Chevrolet...
