Dadnatron
Veteran Member
JD 5100e with just shy of 1200hrs. Purchased used at 450hrs last year. I've put a lot of work on it, IMO given most is weekends and vacations.
Maintenance has been kept up to date. But I had a fault light go on last week while working. It is the main 'check engine' light that doesn't really tell you anything specific but is the 'big deal' light.
I checked codes:
CCU 1883.00 - PTO speed too high. (I had noticed that when I am mowing, the PTO reads up to 590rpm if I am gunning it. I assume this is when it threw the code, but is not associated with the check engine light as I had not mown for several days and the light was new.)
ECU 94.17 - Engine Fuel Rail Pressure issue (?) I've seen people talk about this online, but no one has known what it referred to or what they ultimately did to fix it.
ECU 94.18 - (?) Cannot find the code onling. I suspect it has to do the the Fuel Rail Pressure as well.
ECU 1569.31 - Fuel Power Derate - Again, I suspect this has to do with the Fuel Rail Pressure issue above, but I don't know what this really means. Does it mean the computer has derated available HP until the issue is fixed, or that the issue is resulting in decreased HP? I haven't really noticed a drastic drop in HP, but after reading the code, sometimes I think I talk myself into 'feeling' like its lower. (Should be 100/85 at PTO)
PTr 191.17 - Transmission speed too low. ... Don't know what this means or refers to.
PTr 2825.07 -(?) Cannot find code online
PTr 522456.31 - Cannot find code online
Outside of codes:
The travel speed indicator no longer works. It is simply in the same box that PTO and hours shows up. But when selecting MPH, it says 0.0. It hasn't worked for a few months, but it hasn't been important to what I was doing, and everything else worked, so I hadn't addressed it. I don't see a fuse for it. Everything else works, hours, PTO RPM, etc. But when you roll through the options to MPH, it is just showing 0.0, even when moving. I'd like to have it working for spraying etc. Any thoughts?
I checked codes:
Outside of codes:
