jd 510 ag tractor engine fastener torque specs
   / jd 510 ag tractor engine fastener torque specs #1
Bud Walters
Williams Lake, BC
IHC454
looking for the "exception" to the standard torque specs for the engine on a JD510 tractor
it has a 152CID 3 cylinder diesel, made in france. i need the main bearing cap bolt torque, rod cap bolt torque spec, flywheel bolt spec, head bolt spec and rocker shaft bolt spec
   / jd 510 ag tractor engine fastener torque specs #2
Main bearings - 110 ft lbs
Rod bolts - 60-70 ft lbs
Flywheel - 85 ft lbs
Head Bolts - 110 ft lbs
Rocker shaft - 35 ft lbs
hey thanks . do you happen to have a service book for this tractor or know where i can find one???
   / jd 510 ag tractor engine fastener torque specs #4
   / jd 510 ag tractor engine fastener torque specs #5
Sorry, I dont have a book for the 510. The 152 engine was used in other models that I do have access to. That is where I got the specs.
So is there some way I can get all the pages pertaining to the 152 engine from you, or as in your previous post you would like it better if I purchased the manual ??
2018 Kia Soul Hatchback (A51694)
2018 Kia Soul...
2022 Club Car Tempo Cart (A51694)
2022 Club Car...
Peterbilt (A51692)
Peterbilt (A51692)
2016 Chevrolet Tahoe SUV (A52377)
2016 Chevrolet...
2005 FORD F450 XL SUPER DUTY DUMP TRUCK (A51406)
2005 FORD F450 XL...
2015 Ford Taurus Sedan (A51694)
2015 Ford Taurus...
