jd 510 ag tractor engine fastener torque specs
   / jd 510 ag tractor engine fastener torque specs #1
Bud Walters
Williams Lake, BC
IHC454
looking for the "exception" to the standard torque specs for the engine on a JD510 tractor
it has a 152CID 3 cylinder diesel, made in france. i need the main bearing cap bolt torque, rod cap bolt torque spec, flywheel bolt spec, head bolt spec and rocker shaft bolt spec
   / jd 510 ag tractor engine fastener torque specs #2
Main bearings - 110 ft lbs
Rod bolts - 60-70 ft lbs
Flywheel - 85 ft lbs
Head Bolts - 110 ft lbs
Rocker shaft - 35 ft lbs
hey thanks . do you happen to have a service book for this tractor or know where i can find one???
   / jd 510 ag tractor engine fastener torque specs #4
   / jd 510 ag tractor engine fastener torque specs #5
Sorry, I dont have a book for the 510. The 152 engine was used in other models that I do have access to. That is where I got the specs.
So is there some way I can get all the pages pertaining to the 152 engine from you, or as in your previous post you would like it better if I purchased the manual ??
Cruise Car Electric Utility Cart (A51691)
Cruise Car...
Unused 2025 MS380 Mini Track Loader Skid Steer (A51691)
Unused 2025 MS380...
2015 Arrow Board (A51691)
2015 Arrow Board...
2013 Caterpillar 950K Articulated Wheel Loader (A51691)
2013 Caterpillar...
2018 John Deere HPX615E 4x4 Utility Cart (A51691)
2018 John Deere...
Coleman 274BH Lantern Edition Travel Trailer (A51694)
Coleman 274BH...
