JD 5093E FRONT WEIGHT PLATE BRACKET
   / JD 5093E FRONT WEIGHT PLATE BRACKET #1
Brown Dog
North GA
John Deere 5115M 5101E H260 5115M 540M all MFD
The dealer says Part # R262449.
(Borrowed Internet pix)
It's hollowed out & weighs 117lbs
My buddy's 5425 has # R183722 which looks the same Bolt pattern.
It's Solid & weighs 187lbs.
My question is, will the older heavier solid R183722 fit my 5093E before I order it ??
I'm also gna measure my buddy's bolt pattern, but it's too much trouble to remove & try.
   / JD 5093E FRONT WEIGHT PLATE BRACKET #2
it should, dealer could tell you for sure
Dealer Cldnt tell me cause its not listed.
The bolt holes measure exactly the same both ways though.
It'll fit & it's ordered :D
   / JD 5093E FRONT WEIGHT PLATE BRACKET #4
I noticed the part # R262449 is now listed in jdparts for the 5425, so suspect the reason is the extra heavy bracket (R183722) being phased out in favor of one easier to handle.
But you are ready for that challenge, and glad it is going to work out for you.
I had a feeling that's what was happening.
All this new stuff is lighter & cheesier lol
Kinze 840 Grain Cart (A50514)
Kinze 840 Grain...
2018 Ford Escape SUV (A50324)
2018 Ford Escape...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
John Deere 825i Gator (A50514)
John Deere 825i...
EZ-GO D499 Electric Golf Cart (A51694)
EZ-GO D499...
(4) 3 PLUG VALVES (A52472)
(4) 3 PLUG VALVES...
