gocards1177
Maybe reversing the polarity on the speakers isn't that big of a deal?  It is a tractor after all - I'm not expecting the best sound. If I guess incorrectly is it possible to test it easily?
Would you please include pictures demonstrating the procedure you're suggesting? I'd hate to mess it up.... ; )From the size of the nut, it looks like an antenna,break it off and see if you still have FM.
I believe I did. One side sounded better than the other, so I switched it so they're the same.Did you figure out your speakers? They will play fine reversed, for a bit then the spider diaphragm thingy in the center will eventually let go and you'll have paper weights. In the auto industry speaker wires are usually standardized.
