Buying Advice JD 5075 or New Holland Power master 75
   / JD 5075 or New Holland Power master 75 #1
JB 101
McCormick
On the fence both tractors about the same except for weight and tire size give me some help.
   / JD 5075 or New Holland Power master 75 #2
Has the JD got the 12/12 PR, I absolutely love my 75E.
Good deal I have been told that they were having some brake problems felling spongy along with clutch being real touchy on the new ones. None of this with yours
   / JD 5075 or New Holland Power master 75 #4
I can't say I've had any problems with the brakes. And I have some hilly trails I go on, but I let the engine do the braking and don't get in a hurry.
I will say there is some travel in the pedal (1.5-2.0) that I wouldn't think a new tractor should have, but mine will lock the back tries up easily..
I was asking if the tractor you are looking at has the 12/12 transmission in it? I don't believe I would get a shuttle shift transmission, I was told they are the tractors that have had most of the problems, this came from a guy that worked at my local dealer for several years.
We have two new Hollands at work T155s and they are nice, but the clutch packs have been a real problems with ruff shifting. So much so they will pick the front tires up. And backing up the clutch doesn't allow smooth slipping wile backing into a hole with a batwing. Other than the clutch packs they have been solid performers on some very steep slopes daily. But we do have one in the shop right now with metal in the HYD filter..
The New Holland 75 is probably a good machine too..
Yes both have the 12/12 and thanks for the input both are so close in comparison that it almost depends on buyer satisfaction and thats what I was looking for. Thanks again JB
2014 Nissan Rogue Select SUV (A51694)
2014 Nissan Rogue...
11ft S/A Fuel Tank Trailer Frame (A51691)
11ft S/A Fuel Tank...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2019 Chevrolet Tahoe SUV (A52377)
2019 Chevrolet...
