JD 5045E-needs new starter
/ JD 5045E-needs new starter #1
york
Kubote B3030
JD 5045E only has 600 hrs and starter motor is shot-should i replace with motor from JD or get a after market motor???
/ JD 5045E-needs new starter #2
I assume you are out of warranty.
I put an aftermarket (DB Electrical) starter on my JD 2030. It's been trouble free.
/ JD 5045E-needs new starter #3
What does "starter motor shot" mean ? No crank, pullout frozen, brushes burned up, battery dead, battery cables corroded, bad ground frame to motor, seat switch bad, left in gear, solenoid contacts worn out, etc.
Went to JD and got a rebuild...
/ JD 5045E-needs new starter #5
This sems common in that series. We replaced the starter on our 5055E at 125 hours due to total non start. It was about a month out of warranty so we got an after market starter. We then had the original rebuilt at a local shop (not JD) and put it on the shelf for the next event.
We got this tractor for some light hay work and it has broke down 3 times in 250 operating hours.
Pretty disappointing.
/ JD 5045E-needs new starter #6
Replaced starter on 2015 5065e at 500 hours. Bosch branded OEM starter made in India... Replaced with aftermarket starter from DB electrical .. OEM starter in scrap barrel.
So far, i am happy with my rebuild starter, cost over 400. It really cranks over fast now-starter that came with tractor new, was lame, would not spin the engine, junk...
/ JD 5045E-needs new starter #8
I feel fortunate that my 2009 5055E has been trouble free. It sits outside in the weather year round and has a little under 1000 hrs on it. The only thing I've done to it is to pull the wire off the coolant sensor when I had trouble with intermittent starting. I will agree the starter is anemic though.
(2) Planter Boxes (A66408)
(2) Planter Boxes...
AR500 Coyote Target (A65640)
AR500 Coyote...
LOOK! (A65640)
LOOK! (A65640)
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
Allmand Light Tower (A65579)
Allmand Light...
2001 Ford F-550 Truck, VIN # 1FDAW56F81EC40182 (A65563)
2001 Ford F-550...
