JD 5045D won't start, PTO Engaged light on.
   / JD 5045D won't start, PTO Engaged light on. #1
BDKMHK
John Deere 5045D
I have a JD 5045D that I was starting and turning off a few times while fixing a tire. Suddenly, without changing anything, it won't start and the PTO engaged light comes on when I try to start it. PTO lever safety switch tests good and battery is fully charged. I'm confident it is a safety (PTO) circuit issue but cannot find any info. Two relays behind the dash engage when trying to start it. I need a starting circuit for a JD5045D or advise. Please help.
Update: I bought the $80 PTO Lever switch and replaced it but didn't fix the problem.
   / JD 5045D won't start, PTO Engaged light on. #3
If the tractor thinks that the pto is still on, then perhaps there is wiring damage somewhere.
Being a "no coincidents" kinda person, is any of that wiring near the wheel you were working on?
Hope you figure it out!
  • Good Post
Reactions: D&D
   / JD 5045D won't start, PTO Engaged light on. #4
I had a smiliar issue on my John Deere 7810. Operator wasn't paying attention and hit something, ultimately causing the PTO sensor to give a bad reading later on. The below part number seemed to help the situation. Thanks,
PN: SCU000146
   / JD 5045D won't start, PTO Engaged light on. #5
PN: SCU000146
And that made the tractor not start?
   / JD 5045D won't start, PTO Engaged light on. #6
"If the TPS sensor thinks the tire is flat, it may automatically engage the PTO, especially if someone tried to put back on the tire without airing it. I’d suggest taking it to a local tire shop."
TBN AI bot? ^^^^^
   / JD 5045D won't start, PTO Engaged light on. #7
If the TPMS sensor thinks the tire is flat, it may automatically engage the PTO, especially if someone tried to put back on the tire without airing it. I’d suggest taking it to a local tire shop.
HUH?..... What does TPS have to do with PTO.... Does the tractor in question even have TPS.... IF PTO light is on, troubleshoot PTO circuit.... I would bet there is a failed relay or a wiring short somewhere in the circuit.... First thing to do is get wiring diagram, don't start replacing parts at random hoping to get lucky....
   / JD 5045D won't start, PTO Engaged light on. #8
I would try the easy thing first and reseat all of your relays in your fuse compartment. If that doesn't fix it, Fuse F10 supplies the power to the safety circuit. S06 is the gear shifter neutral switch which is in series in with S02, which is your PTO switch, which is then driving the coil of Relay K05 of the safety circuit.
What year is the tractor?
It's a 2010. It is a very basic tractor, no TPMS or anything like that. There are a few relays but nothing sophisticated in the electrical system. There are two relays that engage behind the dash when I try to start it but nothing else happens (again because the PTO Engaged light comes on). It is a very basic switch that is engaged when the PTO lever is in the off position. I cannot figure out what that switch feeds (relay I assume) in the electrical system.
   / JD 5045D won't start, PTO Engaged light on. #10
First thing is to figure out what turns on light, then work back from there... If it were me, I would pull one relay at at time to see if light goes out and then... Proceed from there....
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
2013 HINO CONV. ICE CREAM TRUCK (A52472)
2013 HINO CONV...
2020 EZ-GO Elite RXV Electric Golf Cart (A50324)
2020 EZ-GO Elite...
2020 EZGO Elite RXV Electric Golf Cart (A50324)
2020 EZGO Elite...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A52748)
3-Point Hitch Root...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
