JD 503 Rotary Cutter
   / JD 503 Rotary Cutter #1
TimberHole
Platinum Member
Missouri
JD9504WD w/ 75 Loader, JD345, Bobcat S150
I recently picked a JD 950 for food plots. I have been looking at used rotary cutters and ran across a nice JD 503 cutter. Can anyone tell me anything about this cutter? Does this cutter have a single blade? What happens if I hit a stump with this cutter? I don't want to tear up the tractor and I'm not sure if this cutter is the right one for me.
Thanks.
   / JD 503 Rotary Cutter #2
Most 503 cutters had a slip clutch...just adjust it so that it works...:)
   / JD 503 Rotary Cutter #3
The 503 should be just like any other rotary cutters in that it has a center carrier or stump jumper, and TWO swinging blades attached with large bolts.
The 503 is a pretty light duty cutter. I wouldnt make a habit of banging it off stumps and getting into thick brush and saplings. Stick to grasses and weeds and it should last a long time
   / JD 503 Rotary Cutter #4
The JD 503 should work well with your JD 950..
Polaris 90 Sportsman 4-Wheeler (A50121)
Polaris 90...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2016 BMW X5 sDrive35i SUV (A50324)
2016 BMW X5...
MILLER SYNCROWAVE 351 TIG WELDER (A52472)
MILLER SYNCROWAVE...
Impact Attenuator Guard Rail (A51692)
Impact Attenuator...
Pneumatic Air Breaker Hammers with Hose (A50322)
Pneumatic Air...
