JD 503 Rotary Cutter
   / JD 503 Rotary Cutter #1
TimberHole
Platinum Member
Missouri
JD9504WD w/ 75 Loader, JD345, Bobcat S150
I recently picked a JD 950 for food plots. I have been looking at used rotary cutters and ran across a nice JD 503 cutter. Can anyone tell me anything about this cutter? Does this cutter have a single blade? What happens if I hit a stump with this cutter? I don't want to tear up the tractor and I'm not sure if this cutter is the right one for me.
Thanks.
   / JD 503 Rotary Cutter #2
Most 503 cutters had a slip clutch...just adjust it so that it works...:)
   / JD 503 Rotary Cutter #3
The 503 should be just like any other rotary cutters in that it has a center carrier or stump jumper, and TWO swinging blades attached with large bolts.
The 503 is a pretty light duty cutter. I wouldnt make a habit of banging it off stumps and getting into thick brush and saplings. Stick to grasses and weeds and it should last a long time
   / JD 503 Rotary Cutter #4
The JD 503 should work well with your JD 950..
Oliver & Dahlman 6' Grapple (A50121)
Oliver & Dahlman...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
Kivel Pallet Forks (A50121)
Kivel Pallet Forks...
(4) Gladiator 12-16.5 Skid Steer Tires (A50121)
(4) Gladiator...
2011 ORTEQ ENERGY SERVICES 40 MANIFOLD TRAILER (A52472)
2011 ORTEQ ENERGY...
377669 (A51573)
377669 (A51573)
