Rotary Cutter JD 503 Rotary cutter
/ JD 503 Rotary cutter #1
DrPhil
Trying to find some information about a 5 ft. JD 503 cutter. Can't find any information on the web. Does anyone know about this cutter? Is it a light duty cutter?
/ JD 503 Rotary cutter #2
Probably too old to find much info on the web. Parts list is available on johndeere.com (at least it was last fall when I bough new blades for mine). Bought mine used, but the owner's manual is copyrighted 1989. I think it would rate closer to today's medium duty models. Manual reccomends tractor pto hp at 18 min, 75 max. Doubt many manufacturer's would reccomend 75 hp on a light duty unit.
/ JD 503 Rotary cutter #3
I had one, kind of a bottom of the line as far as I am concerned. Very light duty cutter.
/ JD 503 Rotary cutter #4
The 503 (and 403) were sold up until the early 2000's.. They are very similar to (if not the same as) the LX 5/4 rotory cutters.. Although my LX 4 come with a slip clutch instead of shear pin on my dads 503
Brian
/ JD 503 Rotary cutter #5
I've got a JD 503. When I got my new Kubota L3400 HST a couple years ago, I got the used 503. I got a manual off ebay for $3.00. I like it. It does all I want, chopping down little saplings while cutting the grass just fine. My neighbor borrowed the 503 to cut 30 acres of really tall reed and grass, everything went fine. I grease it and that's about it. The 503 doesn't seem to be too light compared to what I've seen new, it's a heavy, decent built chunk of steel. BTW, I've got tons of rocks...it just keeps working!
UNUSED FUTURE FT50-(50) 12' PIECES OF GALVALUME (A60432)
UNUSED FUTURE...
(1) 30"X7' ADS DRAIN PIPE (A60432)
(1) 30"X7' ADS...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
Gravely Pro Turn 460 60in. Zero Turn Commercial Mower (A59228)
Gravely Pro Turn...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58214)
2011 NORAM POWER...
