Backhoe JD 49 Backhoe On A 4600 Tractor?
   / JD 49 Backhoe On A 4600 Tractor? #1
quadridermx
Lambertville, MI
Kubota L2500
Hello, I apologize if this has already been asked and covered, but I spent over an hour searching and couldn't find an answer.
I recently acquired a JD 4600hst 4x4 tractor and absolutely love it. I have been looking in the realm of very small 3 point hitch backhoes for some landscaping around my property, but am definitely weary of a 3ph hoe.
A very nice, low hour 49 series backhoe just came up for sale locally and I can get a tremendous price on it. It comes with a subframe for a 5200 tractor. My operator manual lists the 47 and 48 backhoes as the only backhoes for a 4600 tractor.
I realize the 49 backhoe is designed for the 5000 series tractors, but would it be a decent fit for a 4600? I already have a power beyond kit on the tractor.
Both my wife and her father are boilermakers/welders, so I know we could *make* it fit. But would that be a bad idea...?
Anyone have any idea what the weight difference is between a 48 and 49 hoe? I couldn't find weight specs for them.
Any help is appreciated! Thank you
   / JD 49 Backhoe On A 4600 Tractor? #2
I would think the backhoe subframe with the aid of a cutting torch/welder could be modified to fit most any utility tractor.
   / JD 49 Backhoe On A 4600 Tractor? #3
A JD 110tlb is based off of the 4600 tractor and has a 10' hoe. As long as you set up the frame mounting correctly you should be able to make this work. In your case with experienced welders I say go for it.
That's what I was hoping to hear. The tractor is beefy enough to hand it. Thanks!
2019 Isuzu NRR 1,200 Gallon Fuel Transport Truck (A56858)
2019 Isuzu NRR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
200 Gallon Front Mount Tank (A57149)
200 Gallon Front...
WATER TRAILER (A58216)
404 (A52709)
404 (A52709)
Kubota M9000 (A57148)
