JD 4720 with 400x loader, getting loose where mast and end plates attach
   / JD 4720 with 400x loader, getting loose where mast and end plates attach #1
agoff7130
Walls,MS
John Deere 4720
I saw a similar post with a different loader from mine. My loader has round
opposed to the more square ends. There was a shim kit available for it ....
has anyone used a shim kit on the 400x loader to fix this problem?
   / JD 4720 with 400x loader, getting loose where mast and end plates attach #2
Check your loader manual. There are adjusting bolts on the locks. The manual tells how to adjust them.
   / JD 4720 with 400x loader, getting loose where mast and end plates attach #3
Are you talking about where the masts attach to the frame of the tractor?
I have a 4120 and 400X loader and am really close to Walls and will try and help figure out your problem best I can.
   / JD 4720 with 400x loader, getting loose where mast and end plates attach #4
I've had the same problem on my 400X loader. Adjusting the bolts as Chevy mentioned above fixed mine. See your Operators Manual.
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
POLY TOTE W/ WIRE CAGE / PALLET (A52708)
POLY TOTE W/ WIRE...
TANK MANIFOLD (A58216)
2025 MS380R Mini Stand-On Track Loader Skid Steer (A56857)
2025 MS380R Mini...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
COPPER POT & COIL (A58374)
COPPER POT & COIL...
