JD 4720 with 400x loader, getting loose where mast and end plates attach
   / JD 4720 with 400x loader, getting loose where mast and end plates attach #1
agoff7130
Walls,MS
John Deere 4720
I saw a similar post with a different loader from mine. My loader has round
opposed to the more square ends. There was a shim kit available for it ....
has anyone used a shim kit on the 400x loader to fix this problem?
   / JD 4720 with 400x loader, getting loose where mast and end plates attach #2
Check your loader manual. There are adjusting bolts on the locks. The manual tells how to adjust them.
   / JD 4720 with 400x loader, getting loose where mast and end plates attach #3
Are you talking about where the masts attach to the frame of the tractor?
I have a 4120 and 400X loader and am really close to Walls and will try and help figure out your problem best I can.
   / JD 4720 with 400x loader, getting loose where mast and end plates attach #4
I've had the same problem on my 400X loader. Adjusting the bolts as Chevy mentioned above fixed mine. See your Operators Manual.
Unused 2025 CFG QK20R Mini Excavator (A49461)
Unused 2025 CFG...
2013 John Deere 544K Articulated Wheel Loader (A50322)
2013 John Deere...
2012 KENWORTH T800 DAYCAB (INOPERABLE) (A50854)
2012 KENWORTH T800...
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Mulcher (A51039)
2022 JCB 3TS-8T...
IH 1566 Tractor (A50514)
IH 1566 Tractor...
1996 NEW HOLLAND 3930 WITH LOADER (A51243)
1996 NEW HOLLAND...
