JD 4720 Hydraulic Failure
   / JD 4720 Hydraulic Failure #1
blackfalcon
Hey guys. I have a Deere 4720 less then a year old with about 265hrs on it. I haven't drove it much when it was cold. I briefly drove it the other morning when it was around 30 out and I noticed hydraulics seemed to be running a little slow/sluggish. I went to drive it this pm and spent approximately 10 minutes on it. I noticed the hydraulics were running slightly sluggish again, almost like if the fluid was low (which is what happens on my 2720 when its low). I went for a second scoop of loose dirt, the tractor stalled out. I restarted it, and was unable to move bucket, steer, go back and forth etc. etc. Basically complete hydraulic failure. I check fluid and it was right at the top of its range etc. Am I missing something simple that would cause all the hydraulics to fail? Is there anything I should check before calling the dealership.
   / JD 4720 Hydraulic Failure #2
The suction screen would seem most likely.
   / JD 4720 Hydraulic Failure #3
Suction screen is a good idea. Have the filters been recently changed?
Maybe the relief failed and is letting all fluid bypass?
   / JD 4720 Hydraulic Failure #4
IMO no way could this be a dirty oil issue-with those kind of hours I would be standing on the dealer's desk right now-not your problem-that is why we pay the big bucks for that green paint!
   / JD 4720 Hydraulic Failure #5
I would definitely focus on the suction side of things...that's the only common denominator. There are 2 separate pumps (3 counting the hydrostat), so 2 separate relief valves. The power steering pump supplies charge flow to the hydrostat pump. There is a short chunk of suction hose near the pump set also, you may want to look at that too. I suppose that the pump drive coupling could have sheared, but I hope for a suction screen or filter.
I would let the dealer handle it.
The pump drive shaft sheered off from what I was told by the JD dealership. They ordered the part and will be back in business Friday.
   / JD 4720 Hydraulic Failure #8
Was it a manufacturing defect, or something that caused it, or just bad luck?
   / JD 4720 Hydraulic Failure #9
I am not seeing how one pump caused total hyd failure.
A dead implement pump would not affect the transmission.
If it has a steering pump, it should still work.
   / JD 4720 Hydraulic Failure #10
Glad to see ya up and running
2016 Peterbilt 389 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2016 Peterbilt 389...
2018 Ariens Ikon 52in Zero Turn Commercial Mower (A56857)
2018 Ariens Ikon...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
Globel Industrial 44" Water Cooled Fan, 24" Electric Pedestal Fan (A59076)
Globel Industrial...
Honda Pioneer SXS700 4X4 Utility Cart (A55787)
Honda Pioneer...
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
