JD 4720 and Steffen 5508 bale handler
   / JD 4720 and Steffen 5508 bale handler #1
sd2009
What is everyones feeling on using a JD 4720 Compact tractor with a 400 cx loader and the Steffen 5508 square handler. Some people are telling me the
tractor is to light and the loader may not be strong enough.
Thanks for your comments
   / JD 4720 and Steffen 5508 bale handler #2
I don't see why it shouldn't handle it. Your tractor is a little light but with counter balance it should be ok. I run a Hoelscher (I think Steffen is over priced) on a much larger tractor; my grapple weighs 580# and 10- 65# bales only add another 650#. That looks like its within the capacity of your loader. A few things to consider...You will need 3 remotes for the Loader/grapple, you probably need to add weight (think about loading your tires), and you're going to need a decent counterweight on the 3pt (the grapple sticks way out there). If possible, I'd see if I could find one and try it first. Unless you really need the Steffen swivel, I'd look at other brands of grapples. Most are much cheaper.
   / JD 4720 and Steffen 5508 bale handler #3
I've been looking at going that route, too. (JD 4720 with a 8-bale grapple.)
One neighbor has the old, Farmhand 8-bale grapple on his IH 826 and the other neighbor has the 10 bale Hoelscher on his JD 5410. (Steffen's IS overpriced!)
As Mike pointed out - it's not so much the weight - it's the length of the grapple and the extension outward from the loader arms that makes it a challange.
I'd look at filling the tires AND wheel weights (660lbs). As well as something off the 3pt on the rear of the tractor.
The JD ballast box is not too expensive (~$250) and you can fill it with Portland cement; that'll give you another 1,250 lbs.
Let us know how things worked out for you.
AKfish
   / JD 4720 and Steffen 5508 bale handler #4
3 point spike and around bale on the back for ballast.
I bet it will do it fine.
D.
   / JD 4720 and Steffen 5508 bale handler #5
Be careful on uneven ground.
Narrow width, shorter wheelbase and long bale grapple might be less forgiving. If the fields are reasonably flat and level, you shouldn't have a problem, with the proper tire, wheel and 3 point balast.
Check your loader manual for ballast recommendations.
   / JD 4720 and Steffen 5508 bale handler #6
I agree - when I am loading and moving bales with the 4520 - I have a full round bale on the back. Goes on first and comes off last. The wheel weights helped, but need to have the right ballast.
D.
   / JD 4720 and Steffen 5508 bale handler #7
Wonder if the 4720 would be better with R1's set as wide as possible versus R4's? Flip the fronts out, too.
Wider footprint...
AKfish
   / JD 4720 and Steffen 5508 bale handler #8
Wider footprint...
AKfish
As wide and as heavy as possible. Experienced loaders would probably have no issues.
D.
2022 FREIGHTLINER CASCADIA SLEEPER (A51222)
2022 FREIGHTLINER...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A51039)
John Deere 5090E...
1985 International X Con Semi (A50514)
1985 International...
2007 Case IH 2588 4WD Combine (A50657)
2007 Case IH 2588...
1996 PETERBILT 357 35 TON WRECKER (A50505)
1996 PETERBILT 357...
