Tractor Sizing JD 4710 or 5210-not sure what size tractor I need
   / JD 4710 or 5210-not sure what size tractor I need #1
Anonymous Poster
Epic Contributor
I need help figuring out what size JD I need. I raise horses on a 10 acre ranch. I use a tractor for mowing, grading, working up the riding arena (8 ft disk or drag), unloading pallets of shavings (approx. 1000lbs) and moving and stacking 1000+ lb round bales. Right now I borrow tractor for the heavy work.
I'm looking at a new 4710 with loader (24K), a used 5210 with loader (18k, 300hrs), or a new 5105 with loader (21K). I like the size, manueverbility and 4 wheel drive of the 4710, but am concerned that it isn't heavy enough to do what I want. I'm sure the 5210 and 5105 are heavy enough, but they are a bigger tractor and some of the work I do is in tight quarters.
Help!!
   / JD 4710 or 5210-not sure what size tractor I need #2
I do everything and more with a 4600 that you've mentioned.
   / JD 4710 or 5210-not sure what size tractor I need #3
Power reverser transmission aside, if it were me, I think I would go with the a new 5105. It is not that much bigger in size than the 4710 & the engine is bigger (179 cubic inches vs. 133 for the 4710).
If I remember right, you should be able to get the 5105 with a 521 FEL (mid remotes) and dual remotes for around 2K cheaper than the 4710.
The 5210 is a nice machine, just not sure it is that much better than a 5105 for the money.
   / JD 4710 or 5210-not sure what size tractor I need #4
Can you handle bales with your 4600? What sixe, and what limitations?
   / JD 4710 or 5210-not sure what size tractor I need #5
Somewhere on this site I have posted pics of me lifting 1600 lb. round bales. I have done this for 3 years now with mine and no problems. I just put one on the back for counterweight. I lift them up and into round bale feeders and up on hay trailers in the summer. I have lifted thousands of bales with it and zero problems. I know the max. lift is supposed to be 750 lbs. but I have had no problems with mine.
   / JD 4710 or 5210-not sure what size tractor I need #6
Thanks, Doc, thats what I suspected...
great to have a voice of experience.
   / JD 4710 or 5210-not sure what size tractor I need #7
I faced the same decision about a month ago. I now have a 4400 hydro & wanted something larger. I started out looking at at the lower end 5000 series because my nephew has one.
I ended up ordering a 4710 hydro because of the slightly smaller size, the loader specs were not much different & I did not want to give up the hydro. I just hope it gets here sometime soon.
Chris
I know I can handle 1000 lbs with my JD 4400 easily,I have lifted rocks,logs, several bundles of shingles bundles of shingles at a time....I have put over 600 hours on mine 2 1/2 years.I do all of that, but I tip the sucker over with a tiny potato plow on the back... /forums/images/graemlins/crazy.gif
I would say that 4700 would be plenty of tractor(and yes I would like to have a 4710 someday)
   / JD 4710 or 5210-not sure what size tractor I need #9
I agree with the posts on the 4710. My 4700 can handle your listed tasks fine. The hydro and 4 wheel drive are worth the extra $. Get a canopy also.
   / JD 4710 or 5210-not sure what size tractor I need #10
</font><font color="blue" class="small">( Somewhere on this site I have posted pics of me lifting 1600 lb. round bales)</font>
OK each area needs a most important posts archive. That post needs to be in it. That way, maybe, we can find it.
I sure can't
If anone does, could you PLEASE post a link.
TBN search HATES me... /forums/images/graemlins/frown.gif /forums/images/graemlins/confused.gif
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2018 PETERBILT 567 (A50854)
2018 PETERBILT 567...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50774)
STOP!!!! PLEASE...
2014 MACK GU813 GRANITE ROLL OFF TRUCK (A50854)
2014 MACK GU813...
(INOP) NEW HOLLAND B95 BACKHOE (A50459)
(INOP) NEW HOLLAND...
2014 KENWORTH W900 MID-ROOF SLEEPER (A50854)
2014 KENWORTH W900...
